I saw somebody on FBBO that welded up a tool to do this. Basically, it's a metal plate, maybe 5"x6"or so with holes drilled into it that line up with the pinion yoke. It also had a large hole cut in the center to allow access to the pinion bolt.
That plate is welded to a 3ft. bar. You use the rear u-joint bolts (or u-bolts) to bolt to the plate, lift the car slightly so you can get under it, torque (or impact) the pinion bolt & the long bar hits the ground so the rear yoke can't turn.
I've never seen one for sale, just this home-built one.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
