Don't the 1973 or 1974 and later B body use different length and different mounting on the leaf springs than the pre 1973? If so as you have already discovered the leaf springs, non HD, don't work for what you want them to do shruggy The snubber can't fix the springs work
Buy the best springs you can get for what you want them to do up scope twocents
