I agree it may never be checked and it will work but that doesn't make it right. Years ago I did some checking into that rule and was finally convinced it made sense. The result was I removed the dist block totally. I've slept a couple of times since then and can't remember all the details. I do remember I had a hard time even finding out what a differential switch was.
