I'm looking to replace the brittle and dried out engine harness in my 69 plymouth. I've heard that the M&H harness is the best plug and play out there. I saw that Year One has a 30% off coupon if you spend $300 or more but they don't list who makes the harness. I know Classic shows the tag and it says M&H on it but its more expensive than Year One (shocking, I know!)
I'd love to get it and take advantage of the promotion but I want to get a good quality harness so I don't have to worry about any electrical gremlins.
Thanks.
Don't assume it's "plug and play", take the time to compare the repro harness to your old one and the FSM schematics as well, then take the time to check all crimped ends/terminals/rings/etc, and finally use a METER to check continuity of every circuit in the new harness,it's better to find an error/problem when it's out of the car, rather than later, when the troubleshooting gets more complex...DAMHIK
