Originally Posted By dizuster
It's February... head comes off easy... Welded or insert, you know the right answer on if you should fix it on the car.
If it were August and we were at Norwalk, we'd be having a different conversation.
Exactly,with the money invested in that engine nows the time ,fix it correctly.What ever method you can see that it is done right and no issues will be found later.Now is not the time to temporary patch it. up
