just because the wheel cylinders "look" fine, and have no leaks, they can still be locked up from rust. the only way to confirm this is a disassembly of at least the springs to see if the cylinder push pins move in both directions. just be careful if they do move, you don't blow them apart, throwing internal cups and springs into shop "never-to-be-found-land".
beer
