Originally Posted By 340Cuda
A while back I went through this with 5/16" studs. I was not successful in finding anything that was long enough to pull down the rocker shaft and have enough threads not to bottom out before it was tight.
If you are successful please share the solution.
Thanks,
Bill
Did you happen to try any of these, this is what I have found so far...
ARP 200-2402 1/2" course, 1 1/2" fine, ball nose 1/4" 2.7" OL chromoly 170,000 ($16 for 4)
Dorman 675-094 1/2" course, 1 1/2" fine 2.5 OL Grade 8' ($9 for 10 )
Trick Flow 70000100-204 2.25 OL ($15 for 4)
