Originally Posted By Pntastar69
Need to swap out my spool motor mounts. What are the differences between poly and rubber?
watch what brand mfg poly you might decide to buy, as some have been known to melt with high under hood heat, not a job you want to do twice...
FYI I run the Schumacher Magnum poly-loc motor mounts
