Originally Posted By DusTed74
Im putting my dana 60 into the chassis that has the rear leafs moved in the inboard position. My question is where exactly does the drive yoke wind up.
Thank you.
Exactly where you put it whistling
AKA aside, center the pinion yoke in the center of the tranny tunnel before you weld the new perches on the tubes and go from there up scope Set the pinion angle up correctly before welding the perches on also scope
Good luck, welcome to the world of hot rodding and drag racing boogie grin
