Last time I checked, DC needs the same gauge wire for both sides or you will limit the positive to the load carrying capacity of the smaller negative cable. I used to ground to the frame and never had any issues, but now I run a full length ground from battery to block. It may not be necessary, but it does not cost much and your starter will thank you.
