Can't help you with your engine question however, your 73 should have an MDH code on the VIN sticker. MDH stands for month/day/hour. I believe it is in the lower left hand corner of the sticker. That will tell you the day the car was at the end of the production line. That could be before or after the SPD on the fender tag. Good luck!
