Neither the magnum block, nor the LA block have provisions for a fuel pump.
Incorrect, the LA TBI motors did have a long snout cam with the pump eccentric with a block off plate. This changed on some 318s so you have to check before you buy - later cams used a spacer instead of the eccentric (can just swap out) or went to a cam without the provision. AFAIK the 360s all came with the long snout cam and eccentric up until phase out for the magnums.
Ah, the old Moparts illiteracy program. Let me clarify for you.
Neither the magnum
block, nor the LA
As Foghorn Leghorn would say, pay attention son, I say pay attention.
Someone in the thread claimed the magnum block had no provisions for a fuel pump. No [censored] sherlock, none of them do, that's not where the fuel pump mounts.
