^no worries, everyone learns something new here!
do your cars have the wire clip on the steering conector at the box? this clip was put on all 440 installs because the engine was put down in with manifolds installed so the column was removed then put back and the clip held the joint together better then just bending those little tabs.i was at the last reunion and all the 440 cars had them. and who do you think made that mount? not chrysler
I can take a pic if needed since my car is apart
