If it's stock width it should be about 59.5" it should work almost perfect in a duster with the 5.5" backspace wheels and the larger wheelwell that it has.
If you want the rear a bit narrower than a stock A body rear have the housing cut and run 2 pass side axles, it comes out to 56 7/8", a stock A body rear is 57 1/4"
