I have a set of those, will post a pic later. The problems you need to be aware of are the header tube clearances down stream of the flanges because they will be located slightly different with the added flanges. Starter, steering box and shaft, clutch Z-bar, etc. can be a problem. 4 speed cars especially. DAMHIK!
