does this help? Have overhead console for sale
Never seen that bracket. When I removed the headliner board on my survivor to replace the sagging material, it didn't have that bracket. Neither does the one in my AAR I'm finishing up.
That's VERY odd Mike, every Challenger SE or GC headliner/console that I've removed over the decades of parting out E bodies they always had that bracket, it's an often missing item on swap meet removed boards/consoles as it's often left attached to the parts car because of the access to the roof bracket screws, often installed at an angle, (often impossible to access thru the dome lite hole, bracket is installed first, then board is fitted, access thru dome lite hole to support the board center) when removing the entire board assy, or forgotten/dismissed as part of the inner roof structure
Mike
