I took the cover off my Melling 63 HV before installing
Looked clean
Everything moved freely
A little oil
Put the cover back on
Superformance Gasket - Installed o ring on pump
A little black rtv silicone on gasket
Primed the engine before breaking in the cam 10w30w Comp Cams Break In Oil
75 psi at RPM's
25 / 35 psi at Idle
How many engine or machine shops on any make rebuilt engines would actually take apart a brand new oil pump and blueprint it before installing ?
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
