Maybe the TF Cometic gaskets will cover the machining dimples they had on the earlier 240 heads? I had oil leaks from the dimples using the felpro gaskets they suggested. I had to fill the dimples with "right stuff" to get the leaks to stop.
I am using the regular Cometic gaskets without any problems.
