Hello, I'm removing an upper cowl panel off of a 1968 B Body. This is my first attempt removing any cowl panel. My question is, on the window channel corner areas what's the best method for separating the upper cowl panel in these areas? I know that the factory used lead as filler. I want to save all surrounding metal panels. Below are some pics of what I'm working on.
Thanks in advance. beer
