1.920 cd flat top
1/16-1/16-3/16 ring pack
valve notches
accumulater groove
4032 alloy
std 1.094 pin,press or float with forced pin oiling
What's not modern?
The only other thing not modern about them besides the pin is the shorter 1.920" CD. A lower than stock CD; lower compression aftermarket pistons which have plagued 383s for decades.
Why not start with the factory 68/69 HP CD of 1.932", and IF there is a concern of lower deck heights on a particular block, one can simply deck the pistons to the desired CD. Right!? Because you can remove some material from new pistons but cannot add new material to a block.
