why would you run such a small cam on a big inch/ decent compression motor? type in the desktop dyno on the 500" motor with a cam @ or over 600 lift and you will se a significant jump in horsepower without all the compression.
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
