I have a 73 360 in my 69 Dart that I plan on upgrading. It was redone about 10 years ago and has roughly 10k miles on it. It was .030 over with all stock bottom end, cast crank internally balanced, stock rods and flat tops about .110 in the hole. Cylinder walls still have cross hatches and no ridge at the top. I do have a set of 915 J heads w/2.02's that I plan on installing. It will be strickly street driven and may see some time at the track. My goal is @400hp on pump gas. It is a 4 speed w/3.55's.
Would like some suggestions on the build and may be open to a 408 stroker.
Thanks in advance.
