Here is the box in my other sixpack 70 Bee. This is a 802 SPD car that was probably built around 8/12/69. The car has been off the road since 1973
If this is a date good I would guess it is
7 - July
02 - 2nd
9 - 1969
Hello Morty,
Thank you for taking the time to post the pic of the stamped numbers on the steering box. Would it be too much trouble to clean the side of the box and get a picture of the casting number and maybe a pic of the pitman arm to see if it similar to the one that is attached to my box?
If Dan's info from the 1970 parts catalog is correct them it seems I have a A-body V-8 bearing box. Are the boxes the same angle and such? Do they interchange between A,B &E?
Dan,
Thank you for taking the time to respond to my threads!
