Don't try that method, buy, rent or borrow the correct type drum puller and do it correctly up
You may need to add heat on the outer hub with tension on the hubs, especially to get the driver side off wrench hammer
There never easy, how much corrosion form road salts on this truck?
Good luck, don't cut corners on this tsk
