I haven't ever heard of needing 300 degrees F to get the pin to slide out. Usually, hot water from the tap is all that's necessary.
R.
Yes I was worried that I set it too high & luckily I went back in the oven pretty quick. Dog what I am gonna do is put my healing hands on it & see if that does the trick (it usually does!) then if not then hot water then the oven again at maybe 150.
