My Chrysler Service Manuals lists the lifters at Ø0.9040 to Ø0.9045". Lifter bores to be Ø0.9050" to Ø0.9058". You will find that can be from dead nuts on, to over .0025 off, there just isnt a " norm".Many lifters measure .903, or .903 and change. Some measure .9045. Some, within the same set, arent within hardly .0005 of each other. Its a crapshoot.
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
