I have a car with a 416 in it..was a solid roller
and I took that out to run a FT cam.. it has all
the torque that I want.. also I run a 518 OD trans
and elec dumps for the track.. with 4.10 gears
in OD and 295 tires I can cruise at 75mph at 2900
rpms.. it will get side ways in a blink if I roll
into it .. before I swapped cams it was 595HP on
the dyno.. now with fuel injection it drives great
EDIT
it did make 525 torque before the cam awap
wave
