I had this problem on the original 2X3 chassis in my Challenger. I found out that the rack needs to be level with the steering linkage at ride height. It's pretty common sense. If the rack has steering arms that connect to the spindles at down angles, what happens when the suspension is compressed? The toe goes out. There's a little more to it but pretty simple.
