At one time I remember reading that someone had ground one of the tabs of a factory e-body shifter to make it work with a reverse pattern shifter. Basically you pulled it back for second without having to push the button and then for third you would push the button. I have removed the console in my car and I can’t figure out which tab to grind off? Can anyone tell me or engine have a picture?
Thanks in advance!
