Can R3 blocks without the lifter bores bored be used or is the head bolt pattern different also?
I guess there is a possibility that the casting does not have enough meat where the lifters need to go also.
There is a PST with a P5 Patterson motor flying in Comp Eliminator right now. Pretty sure its a 358.
Thanks,
Bill
