My theory is they aren't getting a good ground, and over heating melting the rein. They are case grounded by the case screws to the firewall. What I did was to scrape a little paint off the back at the bolt holes, and the same on the fire wall, then after I installed it, I took the plastic air screen off the cowl, and put toothed washers that would dig into the metal, with self locking nuts.
