I’m talking a complete engine swap, a complete Eagle engine, you’d use the Eagle front cover and accessories. Lock the cam and swap over the necessary sensors but use all the Eagle stuff you can
I can't speak for the Eagle 5.7 but, the 6.4 BGE truck Apache. we have one running in a 06 magnum, pulled the crank swapped a 6.1 32 tooth ring on it, new bearings, locked the cam and away it went,(after some tuning,) Car had Air condition and Power steering removed,only accessory is the Alternator (power rack replaced with a Flaming river custom unit), car has about 22k on it after the swap. Still has the Apache front cover on it.
