Originally Posted By B1MAXX
Originally Posted By Cab_Burge
The clearances are usually made on the pistons to fit a certain size overbore, example the forged Icon piston from KB would be around 4.4440 to 4.4460 for a 4.350 bore while the same size hypereutectic might be from 4.4978 to 4.4980 shruggy
think you meant 4.34xx
should be ok to hone for forged.
If you were going the other way ....that would be a problem.
You are correct up I was trying to use the stock 340 bore size, 4.040 blush
I need to proof read my posts better realcrazy
