Quote: The temp is going crazy on this car. I have lost heat inside the vehicle it works for a moment and then stops. It overheated on Saturday assumed it must the the thermostat.
Any ideas what else it could be?
Craig
it maby just air but i have done stats on those for the same issue. usually just air if temp in vehicle comes and goes. most of the ones i have done stats on have temp gauge running 3/4 gauge instead of half and sometimes flucuating. sounds funny but that's what i have been seeing.
