I am in the same boat as Ron, I love this hobby but don't have much play money and I can't afford a truck and trailer right now and don't have the ability to try new parts out so I built my car with budget in mind and I built it with a torquey motor to pull the 3.23 gears.
My factory stock leaf springs were starting to sag so I had a local leaf spring shop add one leaf to each spring which strengthened the front segment and made the car sit higher so I added one inch lowering blocks. I run Rancho shocks on the rear that were given to me with the adjustment knob on them. I have them set 3 clicks from full soft and may need to go a couple more clicks. Front suspension is bone stock. No snubber.
Yesterday I drove the car 50 minutes to the track, clicked off a 10.69 at 124.65 and drove it home. At the track I do switch rear tires from regular street radials to M/T 275/60 drag radial Pro's. Tire technology has come a long way and these tires are phenominal. There were big tire back-halved cars with lexan windows yesterday dialed a couple tenths slower than me and they were blowing the tires off. My 60 is only 1.51 but it hooks and books.
![Name: FullSizeR.jpg
ID: 304597 FullSizeR.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/304597/filename/FullSizeR.jpg)
1970 Challenger, all aluminum 528 Hemi, HDK suspension, Tremec 5 speed manual
