Stock rockers and shafts. It does have Comp hardened 5/16 pushrods. I would have used the stock ones but didn't have any from the Eagle head donor engine. Compression is in the neighborhood of 12/1. Stock head gaskets. This thing revs very quickly. It's like a 2 cycle. You have to be very careful in the burnout not to turn it over 7000. Yeah it's still pulling like a fright train at 6900. We did stick a used 6.1 oil pump in it for a pressure increase. I think it will live for quite a while under 7k. I have not messed with the timing at all yet. Timing is as delivered from MSD. Doesn't show any signs of detonating at 24* total. I'm gonna put my Sullens E-85 carb on it and see what it does. I think there is a tenth or maybe 2 on the table by just making the switch to E.
