D100. Very sloppy steering. Box is full of fluid and adjusting lock screw turned all the way in
Looks to have play where the shaft comes out to the top end of pitman. I could replace, get it rebuilt or wondering if anyone has bolted a rear steer manual rack and pinion to the back of the straight axle? Looks like it would line up. Just need some type of slide for the steering shaft to allow axle movement. What do you think?
