not sure why a 7x15 with 3.75 bs won't work? or why it hits the caliper?
I have run plenty of steel spoke wheels with 3.75 bs
must not be a mopar slots or 4" on 5 wbp maybe? sure they are 15" ?
I run 7x15 with 4.5 bs weld rims up front with 235/75/15 tire
I have had 7x15 steel spokes with 4" bs also
I have a set of 4x15 with 1.5 bs 165/15 tire
I have seen 10x15 4.5bs on the fronts with 295/50/15 tires...now the stick on weights hit the caliper and had to use bead weights.
I have a set of 10x15 with a 30x9.50x15 tire on the back of my stepside stock width rear axle. so a 8.5 rim 4 or 4.5 bs should fit the rear.
10x15 7.5 bs 325/50/15 M/T with stock width axle & tubs.
I find that 4.5 back space works great on the trucks.
I tubbed my 88 440 truck and used an A-body 8 3/4 to tuck a 12x15 rim 4.5 bs with a 325/50/15 M/T in the fenders.
even the 7x15 4.25 bs cop wheels should bolt right on that truck.
check & ID the wheels
Thanks Scratchin.
And I thought the same. I'll go out and take some photos now. I had no idea they wouldn't fit. A buddy told me that some older mag wheels were cast before disc brakes were popular but I didn't think these were that old. Photos coming shortly.
