Originally Posted By vinnyd76
Anyone know if there are replacement studs available for parts that were captive on exterior trim parts? This part is the quarter/tail panel extension on a 70 Dart (LH and RH).
I'm also looking for a robust procedure for removing the stud. My initial thoughts were to trim the damaged studs down and then drill the stud out followed by tapping the molded stanchion and use of some adhesive.
I did this on my 68 Charger ,similar set up, I ground off the broken stud,drilled & tapped for a stud.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
