Yes it will clear on an RB block. On my engine it ran into the intake manifold so I had to trim the end off of the intake flange.
Do you need a dual sync distributor? I have a brand new one for an RB engine here that I'm not going to use. I decided to go with a cam sync setup and CNP rather than use the distributor.
