Pretty much every engine up to the early 60s emissions era did not use them. Just had a pipe that turned down from a stand pipe on the valve cover, the old push on covers, vented to air. Either way engine must be vented. A good barometer on how the engine is lasting, no blow by, good, a lot, time for overhaul.
