Originally Posted By jkwedge540
Looking to build a small block pro charger motor. What block and heads would you use. 59 or 48 lifter bores. First time messing with a small block. Thanks
If you are looking to stay with a stock block, look for an E58 coded motor. They came in lots of HD optioned cars - late Magnums, 300's, Squads, Taxi's, some trucks. Magnum blocks would be another option. Don't know what HP you are shooting for - assume 700 max with a D1SC? Sonic testing the cyl. walls for sure. Girdle, forged rotating assembly for sure also. Rosary beads hanging from the rear view mirror - - - - . smile
Fastest 300
