Originally Posted By dogdays
The battery should be vented to outside the body. If overcharged the standard lead-acid battery can produce hydrogen with explosive results.
A lithium ion battery contains no water, AFAIK, and cannot produce hydrogen. Now, in certain cases the Li-ion battery itself blows or burns up. Will the NHRA start approving these batteries for in-cab use?
R.
I doubt it. Grays about burnt a Pro Stocker to the ground earlier this year because of one.
If the results don't match the theory, change the theory.
