If your looking at the Ferrea valves, put some thought in the 5000 vs 6000 series.
One set is 2x the other and in most cases the 5000 series are more then enough and lighter as well over the 6000.
If it was sprayed or boosted id consider the 6000 series, at least for the ex. valve.
