Originally Posted By magnum440
im checking fuel pressure next ,its line carbs,but front carb doesnt seem to be squirting as much as rear carb,,thanks for input...
[image]http://file:///C:/Documents%20and%20Settings/XXX/My%20Documents/62%20300.jpg[image]
With the correct linkage you get nothing from the front carb accelerator pump until you are at least half throttle.
