Are you sure the cam lobe is good? I would personally be putting an indicator on it and determining if the lobe is worn.
The way I set the preload is rotating the pushrod till the slightest drag is felt and then go the prescribed turn. I usually do it 2 or 3 times to ensure I get the same result - I look at the position of the allen wrench to determine if the results match. So I don't think it matters if the lifter is pumped up but I have heard others say it does.
67 Coronet 500 9.610 @ 139.20 mph
67 Coronet 500 (street car) 14.82 @ 94 mph
69 GTX (clone) - build in progress......
