There is info about this in the '69 factory service manual for Hemi:
"Ratio (Fan to Crankshaft) 1.20:1"
If the water pump pulley and the fan are turning together, then the diameter of the original water pump pulley is 1.20 times the original crankshaft pulley.
If you don't see two dolphins, you need a vacation.
