I'm not a fan of HS rockers. I run a Chinese rocker and they work fine. Ratio is dead nuts on. All rockers need the geometry corrected.
you don't like HS rockers?? I've just swapped out the std blue Dove rockers & gone to HS on my -1's. they are so much bigger & stronger, they're even bigger than the Ersons i bought off Bondo for -1's. The only thing i had to do to make them fit is swap out the side shims for thinner ones as they were too tight & created drag on the arm. can't believe someone would prefer chinese cheapies over strong as f. HS rockers.
