So I have a 74 charger. Broadcast calls for a "60" under wheel section. Number that I found that I believe corresponds to that is a 3580060. Which is non rallye. I've also seen other numbers but what's the difference between all the numbers for a 14x6? How many different 14x6 wheels are there? How do you decipher the stampings? Thanks.
