While hauling about 9k, the trans temp climbed to 260 this weekend. I'm replacing the original trans cooler with a factory replacement as the internal thermostat may (or may not) be stuck. Looks like the factory coolers are fairly stout. Deep trans pans don't seem to directly help keep the trans fluid cooler. Is there anything else I should be looking at to keep the fluid cooler? Thank-you!
